Old Oct 28, 2013 | 09:34 PM
amx1397
Default Re: rear cat delete test pipes F S
Originally Posted by mobilefitt
What should I expect to pay to have a muffler shop build me this set up?
I had made up 3 sets of the rear cat delete pipes used one on my car sold the other two the problem is to get a muffler shop to remove the cats,,you see it is a $5000 fine if they get caught doing it ,,,so you have to cut them off in front of the cat and unbolt them after the cat then a muffler shop can make and install a pipe. good luck,, $120 is about what you will pay. jim
note: look at the pic and you will see about where to cut.
