Re: Radio help limited coupe 2005
redfire2005
It is me again, one the issue with using the speed control as a accessory for the radio, hitting high rev and speed you blow the fuse and go to shut down. Not good..
New problem; if someone knows where the alarm horn circuit is located on the car. Mine is intermittent and sounds and sickly. Doesn't last long enough to find it, this maybe dumb question but is there a separate horn for the alarm (I ask because it sound different than my regular horns sounds)
The alarm siren is situated under the cowl in front of the windshield, in the center more or less between the windshield wipers.
Removal of the wipers is required to access it. This siren is separate to the horns, which are located in front of the radiator.
The siren fails when its internal battery dies. New sirens ($150) have a beep function when the fob locking buttons are used.
You can see the siren in this thread.
