Old Oct 29, 2013 | 08:20 PM
  #290 (permalink)
Mrmiata's Avatar
Mrmiata
Default Re: Roadster rear window problem solved?
ala_xfire.. as you know I'm new to the roadster.. but shouldn't she hear the pump motor if the switches were okay?
Isn't the basic sequence: Release latch.. at which point that switch lowers the windows.. and when you push it up to the first position.. the switch over the passenger door and the switch in the divider tell the system green light for launch of pump activation which takes place when you push the button.. ?
