Old Oct 30, 2013 | 01:48 PM
bblanchard33's Avatar
bblanchard33
Default
Originally Posted by JEFASOLD
A set of metric sockets, Torx both sockets and drivers and I used a long handle [about 11 inches] bent needle nose plier to pull the plug boots. That will do most of the routine maintenance, oh, also a oil filter wrench. You should be fine. Good luck and enjoy.
I finally took the car to get an alignment check. Lol the previous owner had the tires inflated to max pressure because he thought the tires were supposed to be that full. *facepalm* They also said the toe angle was way off. While on the lift the saw oil had been leaking and accumulated on the bottom of the oil pan.
I took off the engine cover for the first time today. Once that was off it looks like any other motor, except I can see I'm gonna need a good set of Torx bits. Oil is leaking from the passenger side valve cover. Fortunately it doesn't look like a hard fix. Oil level was still fine and color looks good.
