Old Nov 12, 2013 | 10:56 AM
Billy22Bob's Avatar
Billy22Bob
Default Re: Here's one I haven't read about before....
Originally Posted by ckovach
My '32 did the very thing you described for a while and then it went back to behaving properly...I always assumed it might have been related to the (expensive) central locking system vacuum assembly that has notorious problems. I also suspected it was a voltage related issue because, coincidentally, it ceased after I replaced the battery. I know that's not a particularly helpful response, but it was my experience.
Do the SRT/6's have the notorious PSE pump? I guess so - same car - Chrysler wouldnt just change that bit of complex garbage.
As for the water issues that the R170 SLK32/230's PSE experience - maybe not - you dont read about them much over here. Which is interesting because one of the claims over on the MB boards is that the water in the PSE unit is generated from the pump itself and subsequent condensation, and not because rain water runs down the yellow pneumatic tubes and into an upright PSE unit (early days).
If condensation was the case - SRT6 owners dont seem to experience the same issue - so maybe afterall it was the rain issue and the inverting of the PSE unit solved the problem.
