Old Nov 12, 2013 | 12:10 PM
  #82 (permalink)
onehundred80
Default Re: Radio help limited coupe 2005
Originally Posted by redfire2005
Hello Help
I need options> I replace CPS car was working fine until I shut it off. I came back turned the key and it started - then stopped, Did the same again start and stop, on the 3rd try got all the dash lights and no crank.
Days following I cleaned the CPS, reset the connections (try to get in to it and couldn't) module with printed wiring circuit, I got the same response as above - 2 tries but this time no start just crank 3rd time again dash and nothing. I am thinking fuel pump?
Please help and thanks for your endless help
When I see three tries to start the car and then Nada, I think of SKREEM problems.
If it is it is an awkward and sometimes expensive repair.
Have you got another key? It is possible that the chip inside the fob has a problem.
Or the halo ring around the ignition key hole has a problem, if it is disconnected or has a poor connection the car will not start
