Old Nov 12, 2013 | 03:21 PM
syfi's Avatar
syfi
Default Re: Headlight Low-Beam Bulb CLIP problem...
No prob Rich. I've done so many light exchanges now that I can almost do it blind. I now have a snake neck mini led lamp with a magnetic base that's perfect for putting light inside the housing. I like to just take the clip off instead of fiddling with feeding the connector ends through the clip when installing HIDs. A small inspection mirror helps to locate the clip nubs and I now use a bent-nose hemostat to install the clip. The very first one i did where the clip came off took me a couple hours of cursing to get it back on by hand. Now it's off & on in seconds.
