Old Nov 15, 2013 | 03:10 PM
bblanchard33's Avatar
bblanchard33
Default
I tested all the grounds I can reach. The following tested voltage with the engine off, and the engine on.
ENGINE BAY
Battery 12.51, 14.52
G100 12.52, 14.52, left side of engine compartment
G101 12.52, 14.52, right side of engine compartment
G104 12.53, 14.51, top front of engine
G107 12.53, 14.52, right side of engine compartment, battery negative ground
PASSENGER AREA
G200 12.53, 14.46, behind left side of instrument panel at base of windshield
G201 12.53, 14.46, lower left footwell behind kickpanel
G202 under center console at the occupant restraint controller
G203 under the center console
G204 12.53, 14.47, lower right footwell behind kickpanel
G205 12.53, 14.50, upper left rear passenger compartment
G206 12.53, 14.48, lower right footwell behind kickpanel
TRUNK
G300 12.53, 14.50, left luggage compartment behind trim panel
G301 12.53, 14.50, lower right luggage compartment behind trim panel
G303 12.53, 14.50, upper right luggage compartment behind trim panel
I have not removed the center console to reach grounds at G202 and G203. The following components are grounded at these locations:
G202 Occupant Restraint Controller, Driver Seat Belt Tensioner Switch, Passenger Seat Belt Tensioner Switch, Passenger Seat Occupant Simulator, Left Side Impact Sensor, Right Side Impact Sensor
G203 Left Heated Seat Cushion, Left Heated Seat Back, Right Heated Seat Cushion, Right Heated Seat Back, Shift Lever Assembly, Park Brake Switch, Radio, Power Mirror Switch
I don't suspect the G202 and G303 grounds are related to my issues. I'm gonna go after the security module next since issues include the alarm system tripping its self. The alarm module in the trunk is wired to the ICM. I'm curious to see if the Security Module is faulty, and drawing current through the ICM.
