Old Nov 18, 2013 | 02:58 PM
bblanchard33's Avatar
bblanchard33
Default
So before purchasing and installing a new CLP/SSM I decided to do some other tests. I am getting 1.5 ohms of resistance and about 4-5 volts of current in the CAN B Bus (+ and -) connections from the BCM to the CLP/SSM. The manual indicates that anything above 1 ohm should be repaired for and open circuit, and any presence of voltage should be repaired for a short.
I think I may have a short. I don't see any strange looking wires at the harnesses. I can't see anything down the wires that looks burnt or exposed (although I haven't checked the whole thing). Anyone out there have electrical experience to know what some increased resistance and voltage would indicate?
I wonder if I have an exposed section of wire that is barely shorted to ground.
