JesseJamessrt6
How do you get the boost signal? Through the OBDii from DashDaq or through the Zt-2 brain or is there a way to utilize two without confusing the system?
I take my boost signal both from the Zeitronix and the OBDII. The values are different thoguh. The OEM OBDII boost sensor gives the values in dashdaq as KPa this can easily be converted in the zeitronix datalog to PSI. You also have to subtract 14.7 to compensate for the atmospherical pressure. The Zeitronix boost pressure sensor is the best way to go, you get more readings per second and you get a much better accurate value.
/Adam
