pizzaguy
It is hard to say - but any voltage in a circuit makes resistance readings unreliable. To measure for resistance, you need an UN-energized circuit. That is to say, if you are trying to measure a circuit's resistance to ground, the circuit MUST be de-energized.
When I tested continuity, both ends of the wiring harness were disconnected. There should not be any current passing while it's disconnected. The voltage reading came from after I hooked up the B(+) end of the connection.
