Re: Pierburg 0004781701 fuel pump sl55
OK - now I'm more confused than ever . . . I've spent many hours researching this on the forum and with google on the internet . . . I still don't have any definitive answers . . . I don't know where the Pierburg part number 0004781701 (in the subject of this thread) came from??
Here's what I THINK I know . . .
The SL55 fuel pump that is often referenced in the forum to make the fuel system upgrade on our SRT6 cars is a Pierburg PN #7.00228.51. From the Pierburg website http://www.wilmink.nl/pierburg/Pierb...stofpompen.pdf , this pump is a model E3L fuel pump (Go to the bottom section of the PDF you'll find at that link and look in the summary area chart. You'll find the Pierburg pump #7.00228.51 specification summary shown there. This pump has a VERY high flow rate of 300 - 360 liters / hour.
OneHundred80 . . . The links you show in your post (for Pierburg and also on the attachment link) go to a Pierburg pump E1F type pump . . . That is not what we need and if you'll look at the specifications for that pump you referenced the flow rates are very low . . . Installing that pump might well lead to AFR problems and engine damage. I suggest you may want to edit your post?
Now, lets make it even more confusing . . .
I ordered an SL55 fuel pump from CarGuts (they specialize in Mercedes salvage so they should know what they are doing). I expected to get a Pierburg #7.00228.51 pump but received a Pierburg #7.28337.00 pump (looks exactly the same). Following up with the folks a CarGuts, they tell me those two part numbers are interchangeable. I'm not so sure . . . Before I invest the time and effort of installing it and THINKING that everything is right, I'd like to see some definitive specifications showing that the flow rates are the same on those two pumps. The part number of the pump I received does not even show up in the Pierburg PDF in the Pierburg website.
Does ANYBODY have the definitive answers on what Pierburg pumps are acceptable to make our high flow fuel system upgrade? I don't have (and don't want) all the fancy Zietronic equipment so I also don't want to install something that I THINK may be right and end up damaging my engine. H E L P!
PS . . . A final note . . . more than one forum member personally advised me to stay away from the Walbro pump telling me that some users have experienced "problems" after installing the Walbro pump. The Pierburg SL55 pump is apparently the current "go to" pump for making the high flow fuel system upgrade. Just sayin' . . .
