Old Nov 22, 2013 | 02:12 AM
Bay Cruise's Avatar
Bay Cruise
Default OBD readings not fault codes
Ok I just got one of these and see that my intermittent engine management light problem is P0410 so I will check the air pump connectors, vac pipes and relay solder over the weekend. However is there any where on this site, I have searched but failed, where it is explained what all the other measurements and readings mean on all the other pages on the laptop. Is there a "normal" run spec sheet that i can compare my readings to.
