Old Nov 22, 2013 | 10:23 AM
onehundred80
Default Re: OBD readings not fault codes
Originally Posted by Bay Cruise
Ok I just got one of these and see that my intermittent engine management light problem is P0410 so I will check the air pump connectors, vac pipes and relay solder over the weekend. However is there any where on this site, I have searched but failed, where it is explained what all the other measurements and readings mean on all the other pages on the laptop. Is there a "normal" run spec sheet that i can compare my readings to.
This list of codes was once in the documentation thread I think but is not there anymore.
I added it to this post. (click here)
I am not quite sure what you want though.
