Old Nov 23, 2013 | 09:24 PM
Padgett's Avatar
Padgett
Default Re: lower your seat 1 1/2" for $20, easy with pictures
180 - do you work for Microsoft ?
Most of what I work on is pre-1990, have not seen star ("E" ?) bolts before just torx. The seat bolts on my '12 WK2 (Chrysler product) are plain metric hex.
Problem is I do not know if SAE, Metric, Whitworth, or "something else" so want to be sure I buy the right thing.
Is this the right set ? Just the size of the socket I need is enough or is that too difficult.
OK I'll make it even easier: is the seat bolt one of these: E6, E7, E8, E10, E12, E14, and E16 ?
Is this picture better ?
Imagine the crossbar is for chassis stiffness but suspect I could notch & form a saddle in the crossbar to allow about 1" more travel without reducing the torsional rigidity. Could also weld in a stiffener using angle iron if needed.
pps said I was new to Crossfires, didn't say I was new to forums.
