Old Nov 25, 2013 | 12:56 AM
onehundred80
Default Re: Ignition Key Will not turn?? 2005 Coupe
So I take it, if you have to drill the pin, you will be purchasing a new housing?
It just appears that it would be impossible to drill out unless you disassembled more of the dash to get at the pin straight ahead to drill?
James
No, no purchase required. You have to push this pin in if you can turn the key, but if you have had to grind at it you do not have to push it in as it has been ground flush to slide the unit out.
If you have not done this, do it now, Angelo was having trouble with his at Woodward, fortunately he got home OK. Mine was a bit sticky at times and I was not sure if it was the start of the problem or not, when I got home from Woodward I did it just to be safe. You should do it while the key can be turned, grinding at it does not look like fun. You pull the trim away either way, to push the pin in or to see it to grind at it.
