Ignition Key Will not turn?? 2005 Coupe
Old Nov 24, 2013 | 09:30 PM
Default Re: Ignition Key Will not turn?? 2005 Coupe
Mark, I did the fix on my car but the key was not stuck and it was pretty easy. I would like to know in more detail, to help others, what exactly has to be done if the key won't turn. I know you must drill or cut the pin, but how did you do it?
James
Well, yea. I bought the Red Roadster in July of 2009 and knew about the fix after attending the fall Dragon in October 2009.
I never put the fix on that car, tho.
But this one locked up with NO WARNING a month after I bought it.
FIX IT NOW, even if you have NO SYMPTOMS, drilling the pin out due to a lock up makes the job way too tough!!!!
Old Nov 24, 2013 | 09:43 PM
If the key is STUCK, it is said that you wo'nt be able to push that pin in so that you can pull the assembly out. You need to drill the pin out, or at least down to where it will allow you to pull the assembly out.
I got lucky, when the tow truck put the car in my garage, I tried it and the ignition had freed up! I did not drive the car, but took the other one. THEN, next day, took the thing apart and removed the two items and put it back together. So I've never actually had to go thru it, but at least two other guys have called me asking for help. I always have to tell them to just follow the instructions and offer moral support.
I'm trying to remember who went thru this and called me on a Sunday in 2010.... BigKid? It was someone in SC or NC ? ? ? That is who you should ask.
Old Nov 24, 2013 | 10:49 PM
So I take it, if you have to drill the pin, you will be purchasing a new housing?
It just appears that it would be impossible to drill out unless you disassembled more of the dash to get at the pin straight ahead to drill?
James
Old Nov 25, 2013 | 12:56 AM
James
No, no purchase required. You have to push this pin in if you can turn the key, but if you have had to grind at it you do not have to push it in as it has been ground flush to slide the unit out.
If you have not done this, do it now, Angelo was having trouble with his at Woodward, fortunately he got home OK. Mine was a bit sticky at times and I was not sure if it was the start of the problem or not, when I got home from Woodward I did it just to be safe. You should do it while the key can be turned, grinding at it does not look like fun. You pull the trim away either way, to push the pin in or to see it to grind at it.
Old Nov 25, 2013 | 05:15 AM
pjm30144's Avatar
Will do. Appointments at 10am.
Old Nov 25, 2013 | 06:41 AM
Mrmiata's Avatar
Originally Posted by pjm30144
Today 04:15 AM
Well odds are you won't be late
Old Nov 25, 2013 | 06:43 AM
pjm30144's Avatar
How true and I left the key in the ignition so I will be able to turn it.
Old Nov 25, 2013 | 01:34 PM
pjm30144's Avatar
Rocco's European Garage came through. 1 hr 45 min and $195.00 very knowledgeable and polite respectful guys 5 stars from me. Ignition is like butter now
Old Nov 26, 2013 | 08:32 AM
Ed Mahoney's Avatar
Lucky you now I need to find a good mechanic in northern Indiana ???? Thinking about German Concepts in Mishawaka IN. ?? Anyone know of this garage they work on Mercedes, BMW, Audi !!!!
Old Nov 26, 2013 | 08:35 AM
pjm30144's Avatar
I wish I could help. I grew up in Indy but that was a long time ago.
Old Nov 26, 2013 | 10:24 PM
BibaResto's Avatar
Default Ignition Key Will not turn?? 2005 Coupe
Unfortunately the photos for the fix are NLA, or at least they aren't on my computer/monitor.
Biba
Old Nov 26, 2013 | 10:28 PM
Mrmiata's Avatar
I've got the pdf on my computer if you need it.. or should be over in the technical - manuals area on the forum..
Old Nov 26, 2013 | 10:32 PM
Biba
The photos were hosted elsewhere and the accound has (I guess) been closed.
But it does not matter, go back to post 1 in that thread and click on the link to the .PDF - it's all there.
Just after step 4, you will see the link:
https://www.crossfireforum.org/forum...n-key-fix.html
Old Nov 26, 2013 | 10:35 PM
Mrmiata's Avatar
https://www.crossfireforum.org/forum...x-v2-86738.pdf
^^^ see if you can right click and save..
Never mind.. it don't want to play nice.. LOL
Old Nov 27, 2013 | 05:26 AM
pjm30144's Avatar
I also have it saved if you need it.
Old Nov 27, 2013 | 02:26 PM
BibaResto's Avatar
pjm30144, I would appreciate the pdf if you could make it available to me - and perhaps others.
By the way, I only have a single click Apple mouse.
Biba
Old Nov 27, 2013 | 05:46 PM
Biba
Hit this with a single click.
File Type: pdf
Old Nov 27, 2013 | 05:54 PM
  #38 (permalink)
pjm30144's Avatar
Biba
I would be happy to send you the PDF.
Old Nov 27, 2013 | 06:42 PM
  #39 (permalink)
BobbyCaz's Avatar
DO THE FIX!!!!!!!!
i just went thru this. If you can get the key to turn. Get it out. And do the mod. Or you will have to drill it out like i had to.
I cant say it enough.....DO THE MOD!!!!!!
Old Nov 27, 2013 | 07:32 PM
  #40 (permalink)
BibaResto's Avatar
onehundred80, thank you. Once again you've 'come to the rescue'. pdf is now filed away.
Biba
