Old Nov 25, 2013 | 12:16 PM
roland1226's Avatar
roland1226
Default Re: How to remove BELT TENSIONER
Originally Posted by KJN
If I wanted to just change the Tensioner pulley on a 06 Roadster limited, where do I get just the pulley? I see the tensioner available, but not the pulley, and what socket do I need to remove the pulley?
Thanks for the help,
KJN
E-BAY OR AMAZON IS YOUR BEST BET TO FIND YOUR PULLEY.You have TO remove the tension AND THE BELT FROM PULLEY BY LOCATING THE HEX BOSS AT THE LEFT SIDE OF TENSIONER AND ROTATING IT COUNTERCLOCKWISE WITH A 17MM SOCKET.ONCE THE BELT IS OFF ,GO TO THE CENTER OF PULLEY AND REMOVE THE TAMPER PROOF BOSS WITH A T40 BIT.
