roland1226
E-BAY OR AMAZON IS YOUR BEST BET TO FIND YOUR PULLEY.You have TO remove the tension AND THE BELT FROM PULLEY BY LOCATING THE HEX BOSS AT THE LEFT SIDE OF TENSIONER AND ROTATING IT COUNTERCLOCKWISE WITH A 17MM SOCKET.ONCE THE BELT IS OFF ,GO TO THE CENTER OF PULLEY AND REMOVE THE TAMPER PROOF BOSS WITH A T40 BIT.
Roland 1226,
Thanks for the information..If I decide to replace the tensioner, not just the pulley. I read somewhere that there are two bolts holding the tensioner in place. One you can see plainly, the other is hard to get to, as it is underneath the pulley. Do I need to take the pulley off first, or just use the hex boss and turn it lock it in the relaxed belt position to access the second bolt? I may be wrong about the two bolts. Regardless, what size socket and would I need a specialized wrench to remove the tensioner bolts from the engine?
Again, my thanks in advance for any help,
KJN
