Old Nov 27, 2013 | 05:37 PM
  #1937 (permalink)
Buck Spunni's Avatar
Buck Spunni
Originally Posted by pjm30144
I'd be better off with a supercharger too. I can only do so much right now and this was priced right and looks good and is better than the stock setup. I also removed the stock boxes in the corners the stock tubes attached to so I can get much more air in.
You DID remove the stock filters from inside the airbox, right? Otherwise you're just getting a small quantity of VERY clean hot air into your engine.
General consensus is that any benefit from a free flowing filter placed under the hood is more than balanced out by the fact that hot air is less dense than cold air & thus has less oxygen...net result of a hot-air filter is most likely a slight loss in performance, not a gain...
Does look nice though.
