pjm30144
As MR M said this comes with everything you need. I ran a bead of silicone in the stock filter box track then put them back together. Worked well. One note, the drivers side is a tight fit due to the oil cap and power steering reservoir. This makes the drivers side tube angle up and out a bit as you can see in my pics but it turned out great.
Thanks pjm39144 for the heads up on the minor issues...You guys are so helpful and I want you all to know that it is appreciated with the upmost profoundness...Carl...
Are you going to the spring meet??
