Re: New Member Need Help
I had to grind 3mm off my new bolts after going to AMG wheels with 10mm spacers. They made that exact sound on the first test drive so pulled them all off ground them down problem solved. You have most likely destroyed your emergency brake mechanism.
Learn from this! Never drive a car when you have something obviously wrong or you will likely make it worse and cost yourself time money and grief or even worse, get yourself killed.
