Thread: Dashdaq PC
Old Dec 12, 2013 | 10:14 PM
Padgett's Avatar
Padgett
Default Re: Dashdaq PC
a) What part of " What's also important is having access to the most commonly required service features like brake deactivation, service resets, and transmission adaptations-and we do that too." did you miss ? Remapping is different.
b) It is limited to some extent by the sampling rate. The more data points you sample, the longer it takes for each frame since each must be requested sequentially. This is not like the old GM OBD that sent everything in a serial data stream and you had to know where in the stream each data point was (why you had to know the year and engine).
I have not bothered to check the data rate of the Crossfire but the CAN bus in the Jeep is pretty near real time.
Crossfire seems to run pretty cool (around 185F) as it is so I am more interested in monitoring than changing.
