crossfire1989
Hey I purchased the upper and lower grillle. I have the top grille on, no problem. The bottom grilles installed up to the forth step of tightning up the toggle clamps. However, I do not see a place to put the screws on step 5 (figure 3.) Before I go wild with a drill I wanted to check to see if I am needing to create a new hole to put the screw in or is there an existing one I am not seeing? Thank you for your time and answers.
-William
There are no existing holes for the outside self tapping attachment screws in the lower grilles. Just line up the grill and then turn the screw until it "grabs" and screws in firmly.
