Old Dec 19, 2013 | 06:35 PM
onehundred80
Default Re: Valve Cover Gaskets + Oil Separator Reseal Repair Question from Newbie
Originally Posted by oledoc2u
His price is ridiculous. Unless his shop time rates is $200 an hour. Then he is spot on.... It's better to do it yourself. One reason being you can take your time to clean the vent cover up, and apply the RTV. I would let the RTV set up so it will form a good seal. Say 2-3 hrs, overnight if possible. Then put the covers back on. You may have some seepage around the oil filter housing which is from a poor seal when they replaced the filter. That you can take care next oil change. That is about all that leaks in the beginning. I am sure beyond 100K miles, the valve cover gaskets will need replaced as well.
Shop Hours: 1 hour... If in the Christmas spirit 1.5 Hours tops.
Leaving this sitting overnight means it will set up pretty good and if you apply the RTV with ripples in it then the ripples may leak at the deep spots.You need to get the top and bottom faces of the RTV nice and flat. You leave some of the RTV brands a couple of hours lightly nipped together and then tighten it to specification, this ensures that the top and bottom surface of the RTV is flat and matches the two metal faces.
Always follow the directions of the RTV manufacturer.
