ala_xfire
Am I to assume you are in motion at a low speed ?
Nothing with the wheel all the way to the left ?
I it occurs both ways, possible differential problem.
If only to the right, then possible damage to suspension components on the right rear.
Other than that, I'm at a loss .....
Yes could be one of many issues. Could be as simple as a rusty rear rotor and the sound is generated by a brake pad rubbing against the rusty surface. More info required. What was the mechanics justification for "normal" ?
