Old Dec 26, 2013 | 05:32 PM
ala_xfire
Default Re: reverse polarity
The plugs fire at staggered intervals.
From the manual :
The ignition system for the 3.2L and the 3.2L SRT-6 engines utilize a Distributorless Ignition System design. The
ignition system uses a separate ignition coil pack for each cylinder. The one piece coil pack bolts directly to the
cylinder head cover. The coil packs are designed with two secondary towers for each spark plug wire. Rubber boots
seal the secondary terminal ends of the spark plug wires. A separate electrical connector is used for each coil pack.
The camshaft position sensor is a hall effect device, and the crankshaft position sensor is an inductive device. The
camshaft position sensor and crankshaft position sensor generate pulses that are inputs to the PCM. The PCM
determines engine position from these sensors. The PCM calculates injector sequence and ignition timing based on
crankshaft & camshaft position.
The two spark plugs per cylinder are fired slightly out of phase to prevent the cylinder pressures from rising too
quickly, which could cause knocking. To prevent one spark plug from eroding more quickly than the other, they
alternately lead each other. Under normal conditions, the timing is the same for all cylinders, but the timing can be
delayed in individual cylinders if knocking is present in one or more.
Two knock sensors are used to control spark knock. Highly sensitive knock sensors can distinguish knocking
I have run 87 in mine, it seems to adjust fine without knock or detonation, seems to be about the same MPG also.
