reverse polarity
Old Dec 31, 2013 | 02:17 PM
  #81 (permalink)
blueeyes147's Avatar
Default Re: reverse polarity
Originally Posted by Padgett
Cat rattle may be there but you can see the tach drop when it happens so is definitely a misfire. Now the question is "why" ?
For instance if you rev it in neutral then let it drop back to idle does it go away or come back ? When driving does it feel down on power or rough when accelerating particularly around 50 mph/80kph ?
Did it happen suddenly, of has it been coming on for a while ?
Does the exhaust tip have oil in it ? (Looked shiny/black in video).
Hate to be asking 20 questions but have to narrow it down. That video was brilliant and a real help. Thank you.
I dare not walk in these conditions so I can not tell you at the helm, I do not think there is no leakage of oil or fuel, again using a starter after several attempts part correctly, perhaps the highest voltage is able to give more power to the spark plug or coil defective
Old Jan 2, 2014 | 10:17 AM
  #82 (permalink)
SRT6 delivered to the bosch car service hopefully good
Old Jan 9, 2014 | 09:36 PM
  #83 (permalink)
dinasrt's Avatar
Originally Posted by blueeyes147
srt6 delivered to the bosch car service hopefully good
at bosch car service for (1) week............ What is the diagnosis please??
Old Jan 10, 2014 | 10:06 AM
  #84 (permalink)
since he parked them the problem has not arisen game is always correctly and no errors that the ceck, now the car has been parked outside the shop in the cold and must remain firm until Monday in the hope that the defect occurs and ceck to see what the problem is
Old Jan 10, 2014 | 10:52 AM
  #85 (permalink)
Padgett's Avatar
Well it is getting plenty of fresh air and sunshine...
Old Jan 10, 2014 | 01:52 PM
  #86 (permalink)
[QUOTE=Padgett;775581]Well it is getting plenty of fresh air and sunshine...[/QUOTE
Is making me run out of this problem, if not resolved I swear I'll sell
Old Jan 10, 2014 | 02:45 PM
  #87 (permalink)
Padgett's Avatar
Sorry, that was a joke about cars that are supposed to be repaired and are just left in the parking lot.
If it were here I would connect a few data recorders and monitor all of the sensors when it happens. Used to be a good garage would have a big Sun Oscilloscope that could match a trace of the spark going to each cylinder.
Unfortunately the Crossfire seems to have an early form of OBD-II, my Jeep will record misfires by cylinder but the CF doesn't seem to. If it were to go on for a while I'd bet a cheap IR thermometer could pick out which cyl is misfiring (exhaust port will be cooler than others).
Gut feeling is that you have a weak secondary ignition - once it starts does it drive OK or feel down on power sometimes ? Mechanical issues usually do not heal.
Once I had an E-type with a plug that would not fire under 3,000 rpm. Made for very interesting sounds.
2004_
Jul 9, 2025 12:39 AM
xfireohio
Jul 20, 2020 12:03 AM
massanu
Feb 20, 2019 07:06 PM
Billto
16
Sep 1, 2016 11:06 PM
toob
Aug 19, 2015 07:31 AM
