Old Jan 6, 2014 | 01:26 PM
PNA's Avatar
PNA
Default Re: My locks don't lock using the lock/unlock button on my dash (trunk won't unlock!!
Originally Posted by 2006Crossfire
Bill F, yes I have tried that. The only way I can unlock the passanger door is to use the handle from the inside.
Rekcah, I have no idea what that means! I'm sorry, like I said I know nothing about cars other than that they have 4 wheels & require gas!
Thanks, y'all!!
You may need to solicit the assistance of someone who knows a little bit about cars and preferrably someone who knows Crossfires.
A couple things. As Rekcah noted, the mechanism that controls the locks is located in the trunk. You have to lift the liner (easy to do) and you'll see a bunch of black formed styrofoam that houses some tools and the tire pump. Under that styrofoam is the equipment that actuates the locks. If you lift that foarm out carfully, see ithe there is still water in the trunk. If so, dry it out and see if that cures the problems. If not, it could be the system needs repair or replacement.
Other items to check are the fueses (locatd in the fuse panel - check the owners manual) and possibly the switch itself. However, if the remote also fails to work the locks it's more likely the actuater in the trunk or the fures.
Food luck. Do a search on here and there is likely a tutorial to fixing this issue.
