RED DOG
Yes, you can change out the alternator pulley very easily. I happen to have a stock alternator pulley that I just removed from my low mileage SRT6. You can have it for $20.00 delivered to your door.
I find it highly unlikely that all of those pulleys failed (are failing) at the same time. In any event, you can definitely R & R the pulleys yourself but as grip grip said you'll need a special tool to "hold" the crank pulley while removing the bolt and replacing the bolt (you should also get a new crank bolt). That bolt has a VERY high torque and the bolt is difficult to remove and also difficult to re-torque correctly.
SOLD i'll take it.. pay pal?? thanks for the info too..... the tec. told me that when one pulley fails if not taken care of it can make others fail ???....
