Re: pulley went bad
fastfred
around 54k mils on it i have not change ant pulleys or bearings.... i have done supper charger cooling pump and water leak killed my rear comp. ......
i reread you post i i didn't respond to the supper charger bearing that you said to check..... i think the supper charger bearing should be OK i did install a 65 from EURO. last year ...also their tune and e55 clold air intake .... and i bought in the the brake upgrade last year.. had a Little noise at 1st. with the brake shoes but all good now.......
