Thread: pulley went bad
Old Jan 8, 2014 | 05:34 PM
RED DOG's Avatar
RED DOG
Default Re: pulley went bad
Originally Posted by fastfred
i reread you post i i didn't respond to the supper charger bearing that you said to check..... i think the supper charger bearing should be OK i did install a 65 from EURO. last year ...also their tune and e55 clold air intake .... and i bought in the the brake upgrade last year.. had a Little noise at 1st. with the brake shoes but all good now.......
Do you still have that OEM idler pulley on there? If so, that is most likely the source of your noise and I would bet it is probably your ONLY problem. Take off the serpentine belt and spin that pulley . . . see if it spins rough and noisy . . .
