fastfred
WOW.... that sure is a problem the little pulley just left of the supper charger sure makes a lot of noise....
I would suggest you change out that pulley (They ALL go bad because it is a small pulley and it spins too fast causing the bearing to fail prematurely). I suspect that is probably your only problem. Here is a link to buy a new idler pulley (you want that first pulley shown in the link)
Your Parts Search Returned 2 Part(s)
BUT FYI - Rather than put the same pulley back on there, I would suggest you consider the Pulley Saver Kit from Needswings
Pulley Saver Kit Waldig/NeedsWings
or the LateModel 21 belt wrap kit
https://www.crossfireforum.org/forum...l21+pulley+kit
Both will eliminate that (destined to fail) idler pulley.
