Thread: intermitentes
Old Jan 8, 2014 | 11:47 PM
rekcah's Avatar
rekcah
Default Re: intermitentes
Ok, but what about his last complaint, that the system won't lock with the key?
(Actually, Im not sure if he means it wont lock with the key fob, which is how I read it - or if it means it won't lock all locks with the KEY in the DOOR - which, I believe, doesn't happen anyway.)
I actually didn't even notice that part of the post when I read it the first time. lol
I'm not sure about the that last part either. Maybe roadster center console lock?
Originally Posted by davidricca
Muchas gracias por las respuestas y por la traduccion, de verdad. Podrias poner foto o donde esta el rele por favor?? Gracias otra vez.
I found some pictures from member corfire. If you look at picture 3 its the black relay labeled remote keyless entry relay. To get to it you have to remove the whole top cover of the fuse box. It's just held on with those little clips on the side as in picture 2.
Do you have a Coupe or Roadster?
