Hola, mando perfecto , llave problema. Cuando girar llave a la derecha solo abrir puerta piloto. Normal?? Otras puertas cerradas y sonar alarma. Porque?
rekcah
FP, One turn to left unlocks all, one turn to right locks all. Doesn't matter if fob is programmed for 1 or 2 clicks.
I wonder if he has another fob in the ignition.
I have 1 fob programmed to only unlock the driver door with 1 click and the other locks with 2 clicks. Lets call this fob1.
My second fob is programmed to unlock all with 1 click. Lets call this fob_all.
I use fob1 to unlock the driver door and start the car then I use fob_all to manully lock the driver door, as the buttons wont work on fob_all with fob1 in the ignition with car running. I do this on cold mornings.
Now if I use fob_all to unlock the car and start it, then use fob1 to lock the door only the driver door will lock and the passenger/trunk will remain unlocked.
Hope this is understandable.
