Re: Getting Ready for 2014 Autocrossing
Front: camber -3º caster 5.2 toe 0 rake is 1/8" (can't go any lower with the dive under braking without rubbing the inside of the fender well) 245/35/18 on 18x9
Rear camber -1.7º 1/4 toe in 275/35/18 on 18x10 New front shocks on full hard. Rear shocks at 4 clicks (soft) Rear sway bar is set real loose with adjustable links. Car weights 3300 lbs with me seated in the car with 1/2 tank of gas. The rear of the car will come around under heavy trail braking so I brake early and am on the gas just before the apex. The only times I've gotten a push is on the gas coming off slow or medium speed corners. I can lower the rear easily but the front can't go any lower until I have less dive, squat and roll.
Les
Reason: added caster
