Old Jan 17, 2014 | 09:56 AM
GraphiteGhost
Default Re: Mis fire all cylinders
Originally Posted by cfree
So don't replace tank? What did you do to solve yours? Brass insert someone suggested? Mine is spraying more than I thought or it just got worse recently. No puddle on the ground but solid misting all over right side of engine and coolant level low warning is on now. My daughter says she had her bf add fluid about 2-3 weeks ago. Doesn't know how much. Not driving it anymore until fixed so not a big issue.
Thanks for all the help from everyone. MAF should be here this weekend..hope that is the misfire fix.
I hope he used the correct antifreeze! Use the correct stuff. If he didn't flush and fill with the correct 50/50 asap!
