Old Jan 17, 2014 | 09:19 PM
hustler316's Avatar
hustler316
Default Re: Getting Ready for 2014 Autocrossing
Originally Posted by velociabstract
Front: camber -3º caster 5.2 toe 0 rake is 1/8" (can't go any lower with the dive under braking without rubbing the inside of the fender well) 245/35/18 on 18x9
Rear camber -1.7º 1/4 toe in 275/35/18 on 18x10 New front shocks on full hard. Rear shocks at 4 clicks (soft) Rear sway bar is set real loose with adjustable links. Car weights 3300 lbs with me seated in the car with 1/2 tank of gas. The rear of the car will come around under heavy trail braking so I brake early and am on the gas just before the apex. The only times I've gotten a push is on the gas coming off slow or medium speed corners. I can lower the rear easily but the front can't go any lower until I have less dive, squat and roll.
Les
Bring the front up or the rear down. Also if you are running that much camber in the front you may need more camber in the rear, try for -2.5 if you can get it. Everything else looks pretty decent. Your toe is in the rear may be a little aggressive. We run 3/16 toe out in the front and 1/8 toe in on the rear.
