Old Jan 18, 2014 | 10:17 AM
hustler316's Avatar
hustler316
Default Re: Getting Ready for 2014 Autocrossing
Originally Posted by velociabstract
I'll remove some of the rear toe and increase the negative camber in the rear and see what happens. I increased the negative camber up front when I switched to Hoosiers. The front wear looks good and the rears indicate I can run more negative in the rear. I don't want to hurt acceleration so I'll keep the rear camber as upright as possible. I'll try -2º. Of course, all my settings may change with the Ground Control suspension. With less dive, roll and squat I can lower the car more without creating contact with the inner fender wells.
Les
We solved our rubbing with a BFH....I'm guessing you are not going to be following suit lol.
