oledoc2u
So, if I am correct, you have a single NW CAI, 65mm pulley, and a tune?.
OK - I'm going to show my ignorance here. A 65mm pulley is for the S/C I'm guessing which is smaller than the OEM pulley, right?
The 185mm pulley I've seen mentioned in other posts is the crank pulley? And is harder to change and won't net as big of gains as the 65mm as a stand alone mod?
Does the 65mm pulley require a different belt or a pulley saver kit (PSK) that I've read about?
I've seen smaller S/C pulleys mentioned (maybe a 62mm?) but does that make a huge difference from the 65mm? Also, what is the size of our OEM S/C pulley?
Sorry for all the questions but after seeing all of these mods mentioned, I'm a little confused.
Thanks - RL
