Old Jan 24, 2014 | 05:42 PM
onehundred80
Default Re: Paper vs Fleece Oil Filter
Originally Posted by KrisFire
I'll go ahead and get the fleece in ASAP then. I get paid next week, so I'll grab it then. When I do do the swap, should I add any more oil in since the old one will be saturated with just a bit of oil? I've still got 2 quarts left so it's not an issue if I have to add a little in.
And thanks for the support. I just had to put new tires, brakes, wipers, and get the oil changed. When I got the tires done, I also found out that the alignment is off, so that will cost me another $70 to get that fixed. Oh the joys of car maintenance.
Unscrew the filter and if it is soaking with oil leave it loose in the hole for an hour to drain back into the engine. No need to add more oil, the amount is hardly anything when it is drained back and it's really OK even if it's still dripping with oil.
The oil filter hole (sans filter naturally) is the easiest place to refill the oil, it acts as a natural funnel that will not move if you nudge it.
