Problem, help needed!!!
Jan 26, 2014 | 09:59 AM
permalink
onehundred80
Apr 2006
25,432
647
Ontario
Re: Problem, help needed!!!
Quote:
Woodgang
Sorry, see if these work better, parts in pics are immediately to the left and right of the rear diff.
Grease / oil only seem to be on one side of the circumference of the part as if it leaked out while sitting stationary?
Any ideas? 14000 miles on car
Thanks
I cannot get the pics bigger as well.
I looked at the Service Manual and I think you are OK.
Quote - 'HALF SHAFT VISUAL INSPECTION
1. Check for grease in the vicinity of the inboard and outboard CV joint. If grease is present, this may be a sign that the inner or outer boots, or the retaining clamps are damaged.
2. A light film of grease may appear on the inner CV boot; this is considered normal and should not require replacement of the boot. All inner CV boots are made of silicone rubber; which will allow weeping of the joint lubricant to pass through the boot while in operation.'
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
