Thread: 2004 V8 6-speed
Old Jan 27, 2014 | 12:54 PM
  #440 (permalink)
sk8erjosh09's Avatar
sk8erjosh09
Default Re: 2004 V8 6-speed
Simple - move
Or let me 'borrow' your car until you can make it to Indy, I will take really good care of her, and if you are lucky, I will buff that paint LOL
LMAO, if the referee doesn't work out then we may have a deal honestly.
Why even point it out to the ref? Would he notice the two extra cylinders you think?
I went to the ordinary smog shops in town to try but apparently our town was raided a year ago up to 3 months ago and smog shops were penalized for illegally passing engine swapped cars. They look now.
The referee is different. They closely examine your engine swap to determine if the smog equipment is all there, and functional, to approve the use on road. They slap a barcode on and report to the DMV that your VIN is now associated with a different motor. Then you can go to any normal smog shop for smogs. However they also check the year the engine was certified for. I have no idea how they pull up this info unless they have Star DAS with the EPC but it doesn't matter. If the year is caught then I'm screwed, unless I prove that '03-'06 SL500's have no difference in configuration or functionality.
One thought I had (which sucks) is to creat an exel file with '03 part numbers vs the '06 part numbers to show they are the same for smog equipment. To add to that, I was thinking of collecting pictures for '03's and '06's.
