Old Jan 27, 2014 | 03:35 PM
shaag78749's Avatar
shaag78749
Default Re: Getting Ready for 2014 Autocrossing
Well, yesterday didn't turn out as I had hoped. I was third in a class of eight. Two of the faster guys in FS ran in the X-Pro class. So, I was really fifth out of ten.
The car didn't handle as well as I had anticipated. The front stuck really well--never pushed once. The rear, however, was very loose. I didn't adjust the Konis in the rear (they are set in the middle between full stiff and full soft). I need to get some practice and try setting them softer. The fronts were 1/4 turn from full stiff. I think that I'll increase the fronts to full stiff. I had 38 psi in the fronts, which according to the scuffing, was good. The rears had 37 psi, but I eventually dropped them to 35 psi.
My fastest raw time (I hit one cone) was my first run, which never is the case. I should have improved by at least 2-3 seconds, but on each run, the rear was really loose.
It was a 38-45 second course, depending on the car and driver. I should have been in the 40s, but I was in the 44s most of the runs. We only got four runs (there were more than 150 drivers registered).
Any advice on setup would be appreciated.
The results are here: https://axwaresystems.com/axorm/cale...iewevent=11667
