Old Jan 27, 2014 | 10:03 PM
BibaResto's Avatar
BibaResto
Default 3-piece windshield surround
I had no idea that others were also looking for these three pieces - and that their going rate is quite high. I will say that the design and means of attachment is quite sophisticated - though for the latter, it is definitely overkill. A bear (at least for me) to unsnap, then later install. Lots of various types of screwdrivers were used in the operation.
I used an industrial type paint. This makes no sense, but the outer layer is perfectly smooth after the final 2500 grit sanding, but you look at it once polished out, and there is a lot of orange peel.
However, not the major problem for me. I feel the medium to dark red paint I used is way too bright in the daytime, though looks great (at least to me) in the shade or evening. I'll also add that I painted my aftermarket 3-piece mesh grill the same color and it is fine because of the black behind it.
I will be sanding forever to get the windshield surround entirely smooth before repainting since the industrial paint is made to take a beating and I applied three coats.
Biba
Black '07 Coupe Ltd.
