Old Jan 28, 2014 | 10:03 PM
cfree's Avatar
cfree
Default Re: Mis fire all cylinders
Originally Posted by sk8erjosh09
You are in Vegas? I will be there February 13th around 8-9pm. I'll have my star diagnostics system with me if you would like to get together. If none of those changed the issue then I'm at a loss. Have you checked your RCM?
Would the RCM be throwing its own code? When reading codes it randomly goes from cylinder to cylinder but the only codes are cylinder mis fire. I ruled out coil packs since its random and all cylinders. Is that a mistake? Also plugs and wires for the same reason. I feel it must be something simple I am over looking. I read the post on rcm repair and will be contacting tighed1 this week. Seems like a good idea even if not my current problem. Thanks for any input and help.
