Old Jan 29, 2014 | 10:12 AM
onehundred80
Default Re: Thoughts on Preventive Breakdown
Originally Posted by FP
So, if I'm getting the P0410 code on both RCMs now, do you think I have a bad pump? Is it hard to replace the pump if that's what's wrong now? I didn't have any issues with my RCM or pump before I replaces my RCM with DJ's. I disconnected the battery per instructions prior to swapping them. Could the swap have caused the pump to fail?
Check the ground wire of the pump, you can see it on the front of the pump. I think something on it is green.
