Thoughts on Preventive Breakdown
Old Jan 30, 2014 | 09:19 AM
  #41 (permalink)
Djo's Avatar
Djo
Default Re: Thoughts on Preventive Breakdown
The sticky key thing I hear it mentioned a lot . How much would it cost for a good mechanic to replace It, Doubt I could do it myself
Old Jan 30, 2014 | 09:49 AM
  #42 (permalink)
IBLUBYU's Avatar
In my case the ignition sticky icky came on gradually over a couple of weeks. I decided to do it my self before the key wouldn't turn at all. Followed the directions here posted, and if I can do it, anyone with a little mechanical ability can. The biggest challenge was getting the ole body to contort, and then stand up again. LOL That was 18 months ago, and still slick as snot.
Old Jan 30, 2014 | 02:45 PM
  #43 (permalink)
meh03's Avatar
I'm going to check my RCM this weekend. The fix sounds easy. I had to replace the CPS at 30,000 miles. Now I keep a spare in the glove box. It's bad how they go out and can kill you car while driving. Knock on wood that nobody has had an accident so far from it.
Old Feb 1, 2014 | 12:04 AM
  #44 (permalink)
gguillot's Avatar
If you are planning on driving a Crossfire on a daily basis, do the Sticky Key Fix, RCM fix and the CPS replacement. Otherwise, plan on having the car towed home at some point. The CPS took mine out on the way home from work one day. Had to have it towed. It's only $40 for a new sensor off Amazon and that's for the Bosch unit. I keep a spare handy as well. It only takes a few minutes to change if you have the right tools.
Old Feb 1, 2014 | 08:08 AM
  #45 (permalink)
In the "right tools", include a pair of heavy duty gloves. Changing the CPS on a hot engine is not fun.
Old Feb 1, 2014 | 09:19 AM
  #46 (permalink)
Why you would change a CPS that is working fine confuses me. You could put in a new part and have it fail, that's what electrical parts do. They can last for ages or go in a second.
Keep a spare in your trunk and keep your fingers crossed.
Old Feb 1, 2014 | 11:13 AM
  #47 (permalink)
Dementors's Avatar
Wow, sounds like I have some work to do as I have not done any of this and I am at 36,000 miles. Time to start using the search function!
smfrycruzr
Jul 17, 2023 05:33 PM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
Sep 28, 2015 07:40 PM
rfourt
Sep 25, 2015 01:38 PM
BEATv1
Sep 10, 2015 12:58 PM
