Old Jan 29, 2014 | 03:33 PM
cfree's Avatar
cfree
Default Re: Mis fire all cylinders
Originally Posted by sk8erjosh09
The RCM wouldn't throw it's own code, it is just a Relay Gateway, or housing if you will. The relay's are for things like the fuel pump, air pump, traction control etc.. We've heard all kinds of weird stories from the contacts or relays going bad. If the contacts are on there way to going bad for the fuel pump, it wouldn't surprise me if it was misfiring. Has it ever not cranked? Where all the lights are on, and the key does nothing? Or has it ever died on you while driving down the road?
It starts and runs. Obvious misfire while driving. Has not died while driving. About 6 months ago my daughter was driving and she said it wouldn't crank. I went to check it out and it started right up, no code. This problem started about a month ago. Hard to start and misfire. Once warm I could turn off and back on it would run fine. Next day I had had codes checked and reset computer. No problem for a week. Then same thing and won't clear up after restart.
