Old Feb 10, 2014 | 11:18 AM
Mrmiata's Avatar
Mrmiata
Default Re: replace engine coolant
Originally Posted by dtinker
I think I am just going to drain and flush with engine running so T-stat opens up, etc. I noticed that the pics show changing out the t-stat and gasket. I don't think I will do that unless some really good reason. Car does not get hot, t-stat works fine, no leaks. I assume this is changed more for inspection than for anything else. I am going to buy Zerex GO-5, HOW MUCH SHOULD I buy? I think I will buy the 50-50 premixed, does it take 3 gals?
Since you didn't go into detail.. You realize getting the engine hot to open the thermostat and then inducing cold water is not a good combination.. not to mention the thermostat will then close with the cooler temp from the water. So unless you intend to hook up to the home hot water tank..
